For those who want to sync their documents to a server running on your own Local Area Network (LAN), WebDAV is a great option for that.
To connect to your WebDAV server, click the WevDAV option on the Sync Settings screen:
You will be asked to enter the address of your WebDAV server, your username, and password. Click the Switch to WebDAV button to login to your server.
WebDAV Server Software
Tap Forms Pro does not ship with a WebDAV server, but you can find some WebDAV server software on the Mac App Store or other locations. The two I’ve been using are basic WebDAV servers that run on the Mac. They’re not fancy, but they do the job:
I have no affiliation with the people or companies who make these apps.
