To configure synchronization with nearby devices via Wi-Fi:
  1. Open the same database document on each device you want to sync with
  2. Under the Tap Forms menu, select Settings / Preferences
  3. Click Sync
  4. Click Nearby
  5. Click Done
Do the same on all of your devices so that Tap Forms on each device is connected to each other. You will need to do this with every database document that you want to sync with each of your other devices when using Nearby Sync.
Tap Forms Pro will go through an initial sync setup process. When that stops, Tap Forms Pro will be ready to sync with another device.
It’s also possible to have some devices syncing one document and other devices syncing other documents. For example, you may want to sync your private information with just your devices, but sync your shared information with a family member or co-worker with one or more of their devices.
Last modified: Jan 17, 2026
