To spark ideas and provide easy access to an ever expanding list of commonly used, freely available forms, Tap Forms Pro offers a new Template Library feature.
With the template library, you can import any or all of the templates provided into any of your opened documents. Just select from the list of categories on the left, then select a form, view the list of fields already available in the form template, then click the Import Form button. The form and any sample records will be imported into the currently opened document.
You can then customize the form to meet your exact needs if you wish.
