With 28 different field types, Tap Forms Pro can be extraordinarily flexible in how your data is managed and presented. Fields are the way you identify what data you want to capture. A field’s type defines the kind of data you’ll store in that field.
To create fields in your forms:
- Open the Form panel and click the “Fields” tab
- Click the + button beneath the field list
- Choose the field type
- Provide the field title
For fields that have already been created, select one to edit its name, description, and label color. Additionally, there are options to require the field during record creation and show the title on the list view, both activated by a check box.
While the above attributes will remain the same as you switch between field types, each field also features its own unique set of settings that allow you to further customize its functionality. For example, the Number field contains options for incrementation, number format, currency, and more. Through reviewing and updating each field’s individual choices, you can better understand how the fields can work for you.
